After 17 years I still make this mistake.
So you've been working on something and feel you've messed up. So you revert the VI, only to find out the first 70% was not messed up... Sadly, you can't undo the revert.
I know it's a bit "against the nature" of the revert as it has been for the past 15-20(?) years, but maybe it's time for a change? I do understand it might be difficult from a technical point of view as the bkup-heap as they are probably won't support this...
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
