wiebe@CARYA
Undo-able revert
Status: Declined
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
After 17 years I still make this mistake.
So you've been working on something and feel you've messed up. So you revert the VI, only to find out the first 70% was not messed up... Sadly, you can't undo the revert.
I know it's a bit "against the nature" of the revert as it has been for the past 15-20(?) years, but maybe it's time for a change? I do understand it might be difficult from a technical point of view as the bkup-heap as they are probably won't support this...
5 Comments
Mythilt
Actually, the automatic backup feature could be used to allow for undoing reverts (This is the feature that allows for recovery after a crash.) simply have it do an auto-temp file save and to undo the revert just reload the temp file...main thing here is that it would still be a load from file, so your history would still be lost, but the original pre-revert file would be there.
Jon D
Certified LabVIEW Developer.
wiebe@CARYA
Knight of NI
Doesn't sound that simple. I'll have to dig into it to actually see what you're talking about and hopefully remember it the next time I need it...
I'd prefer an Undo.
Mythilt
I wasn't suggesting that is what you should try doing, rather that it probably wouldn't be that difficult for NI to implement using the auto-backup feature.
Jon D
wiebe@CARYA
Knight of NI
Ah, I though that might be what you mend after (always after..) my reply.
It wouldn't be perfect with losing the undo history, but it would be more then we have now.
Darren
Proven Zealot
Status changed to: Declined
