User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
Hello Team,
When Text Ring is wired to Case Structure, the Case Selector Label displays the Item Values (Numeric) instead of Item Name. It is difficult to keep track of values when we work with large Item Values like error code etc… and also have another issue, if we update the Item Value of an Item in the control, the Case Structure Label does not get automatically updated.
It would be useful we have functionality similar to ‘Enum’ when wired to Case Structure, the Case Selector Label displays the Enum Names and also automatically updates the Enum Names in the Case Selector Label if the Item Names are updated.
Enum can’t be used in this case because the Item Values are sequential and can’t give defined values for the Items Names.
In general when the Text Ring is wired to Case Structure:
or
The Subdiagram Label should be automatically displayed with Item Name.
