It is 2011, and everyone is either making the transition to 64bit, or have already done so. Yet LabView on Linux is still stuck in 32bit, and this means that for modern Linux installations you have to install a ton of 32bit support libraries just to run LabView. Not to mention missing out on all the 64bit fun that everyone else enjoys these days, such as access to more memory. Please do something about this.
Principal Software Engineer :: Configuration Based Software Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018) Software Engineer :: Measurements RLP Group (until Mar 2014) Applications Engineer :: High Speed Product Group (until Sep 2008)
We need 64-bit LabView in order to avoid installing a huge army of 32-bit compatibility libraries to run it. It would also make writing support functions in C for it simpler on 64-bit systems.
I raised the 'Linux question' at an NI open day yesterday and the news is not too encouraging. NI do not envisage increasing Linux support, in fact there may be less Linux development in future - this as a result of a lack of customer demand.
FYI - LabVIEW 32-bit installs on non-rpm systems like 32-bit Ubuntu, but neither the 32 or 64-bit version will install on 64-bit Ubuntu. 64-bit LabVIEW installs and runs fine on CentOS. I don't need hardware support in my application so I have not tested it on either platform.
Available with LabVIEW 2014 and later
