tst
Supercharge Quick Drop - Turn QD keyboard shortcuts into first class citizens
Status: New
tl;dr  There's a summary at the bottom if this is too long for you.
Quick Drop is pretty useful when it comes to dropping things and the fact that it also gets items from the project is great.
What I don't like about QD, however, is the keyboard shortcuts. These allow you to perform custom actions in LV and the concept itself is great, but the implementation QD uses has some issues which other similar tools like the right-click framework and LabVIEW Speak don't have, such as the items in the following list.
The problems:
  • It requires you to remember keyboard combos to call the plugins. That's great as a secondary access mechanism, but is terrible as a main one for a few reasons:
    1. It is not discoverable.
    2. It requires you to remember key combos.
    3. It doesn't work if you want a longer list of macros which perform all kinds of useful operations, because you run out of available shortcuts.
    4. Likewise, you have shortcut collisions, because people want to use the same shortcut for different plugins, so you might say "Ctrl+T", and it will mean something else to the person you're talking to.
  • Setting options on the plugins is done by pressing the Shift key or other similar magic combos instead of having a clear representation in the user interface.
So, what can we do about it?
I think a good first step would be to stop thinking of these as "keyboard shortcuts". They should be thought of as custom actions or macros and they should simply appear in the list
along with the regular items, like so:
There are a few things to point out in this image:
  • The actions appear in the list using their full names and they have a glyph to set them apart from the other items.
  • The actions may (or may not) have a shortcut.
  • The actions may (or may not) have a keyboard shortcut (and there's no reason in principle why regular items can't have them too). This solves the existing problem of the shortcut limit - you only assign shortcuts to actions you access regularly, just like you can already do today with menu items.
  • There's a ring on the bottom which shows just the items, just the actions, or both. Ideally, the value of this ring would also be settable by other means (e.g. open QD using Ctrl+Shift+Space and the list only shows the actions or open QD when you have a selection and the list only shows the actions).
OK, so that's step one and it solves the first issue - the actions are discoverable, accessible and not limited in number.
Now step two - some of you may have noticed that the image has another new thing - there's an expand button on the right side.
Clicking that button will open this panel:
This area shows the details of the currently selected action and allows selecting options for it.
Here's what we see in this example:
  • A title.
  • A description.
  • An image.
  • In the settings area, I gave the "Build array of references" action an option - you can choose to align the Build Array node to the center, the top or the bottom of the references.
The panel should remember its last open setting between calls and when it's open, it should work asynchronously, so that it doesn't delay the operation of QD.
For the VIs which appear in the panel, there should be a standard template for loading and saving values, for showing titles and help data and for shutting down. If the VI fails to respond to the shutdown command within N ms, Quick Drop should proceed and not wait for it.
Of course, once we have this panel, the next logical step is to also have it show the help for standard items, similar to this idea:
So, to sum up:
  1. Custom actions should be in the list of Quick Drop items.
  2. Shortcuts for actions and items should be fully customizable. That means that you can still use keyboard shortcuts to call the actions, just like today.
  3. There should be a panel which allows customizing options for actions and show the help for regular items.
___________________
Try to take over the world!
12 Comments
tst
Knight of NI Knight of NI
Knight of NI
I'm not aware of anything along these lines anywhere. Note that for something like this to work without NI doing it, you would have to recreate the Quick Drop dialog itself and then also create plugins which work with new system (or wrappers around existing plugins which will format the data like each plugin wants it).
Personally, I tend to use the popup menu plugins more often than QD shortcuts, but that's a matter of personal preference.
The only thing I can suggest which you can do immediately is to go into the shortcuts dialog in QD and configure only the shortcuts you actually use, but that still limits you to however many shortcuts can be configure.
___________________
Ajay_MV
I'm not sure about popup menu plugin. However I did try myself changing the shortcuts in QD settings, but the challenge is when each developer has their own shortcuts for different plugin. Most of the time, I myself have to reconfirm and try to remember by looking into the QD settings.
Ajay MV
