User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
I envision a structure much like a case structure, in which you select your event for evaluating the code inside the structure and the values become constants at the node. The interior would allow code that may normally not be able to run on the host for example, on fpga it might allow the use of doubles and strings and resized arrays, because it isn't actually going to be executed on the host just evaluated and stored as a constant. This would allow for more configuration for fpga and even have some benefits at the traditional desktop environment. For example you could set the structure to evaluate on app build and produce a string constant that is the build date so the build date could be shown on UI to help distinguish builds.
