User | Kudos |
4 | |
2 | |
2 | |
1 | |
1 |
Please can the installer be changed to stop using removable drives as a temporary location for installation files. I had a 2TB drive attached when I started the install and "safely removed" it part way through. The install then failed
I assume it uses the largest attached drive available. If possible could it check for the fastest drive instead. My main drive is an SSD with an HDD as the secondary drive which is larger. The SSD would have been the best choice in this instance.
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
