JDinkins
Split Number/Join Numbers primitive connector placement
Status: New
Re-opening because of a request to reconsider this functionality for LabVIEW now that LabVIEW NXG has been discontinued.
The connectors hi(x) & lo(x) on the primitives for "Split Number" & "Join Numbers" do not line up with multi-connector primitives (Index Array, Build Array, Format, Format into String, Scan from String, etc). See below:
14 Comments
GregSands
Yes, all those small things bug me too!   I usually end up hiding the bend under one of the primatives, but fixing it is preferable.
TiTou
Trusted Enthusiast
yep, and while you're at it, do the same for variant (i think there is already in idea for that) and "to more specific class"
Epictetus
Antoine Chalons
David_L
Good call.  While not a duplicate, you can definitely file this one with Change error terminals of Variant to Data function to match every other VI and Function in LabVIEW
crossrulz
Knight of NI
It's always the small things that annoy you the most.  This is one of those for me.
GCentral
stbe
There's also the "To More Specific Class" that doesn't really fit to property and invoke nodes ...
_________________________
CLA
JackDunaway
Trusted Enthusiast
Check out the other thread David_L links to above. I'll paste three snapshots from that link:
Guy Drew
Nice and simple
vitoi
Build Array is correct with 8 pixels of separation. Split Number has 9 pixels of separation, so should be the one to change. Having everything on 8 pixel seperation makes things nice when wiring. (It's also the separation on a standard 4:2:2:4 subVI icon.)
Darren
Proven Zealot
Status changed to: In Development
Darren
Proven Zealot
Status changed to: Completed
Available in LabVIEW NXG 1.0. All node terminal positions should be positioned in increments of 5 pixels, so wiring one node to another should result in wires with no bends, or bends of 5, 10, 15, etc. pixels.
