User | Kudos |
4 | |
3 | |
2 | |
1 | |
1 |
I find it always a hassle to create an asynchronous call with the need of the "Open VI Reference" block. A strict static VI reference should be sufficient. Options should be either available in the properties via context menu, via property node or as input of the "Start Asynchronous Call Node".
I didn't go through the effort to create a property menu example, but here is an a graphic showing the help example and what I would wish for:
