User | Kudos |
17 | |
5 | |
4 | |
4 | |
4 |
Working with class method VIs becomes easily confusing if you need to use VIs from several classes that are inherited from each other. Every class adds or overwrites VIs from one of the ancestor classes but usually you don't know which one. And if you're just user and not developer of this class structure you're usually also not interested in the exact inheritance hierarchy.
Look at the picture: As programmer of the application "main.vi" I'm just interested in Class 3 but I also need to know the internals of Class 1 and Class 2 whereby Class 1 is not even in my project. So I can't see that there are also other cool methods within Class 1 and to get methods from Class 2 I also have to search inside of it and compare against Class 3.
As reference: This is the content of Class 1
What I suggest and expect is the following:
=> The class tree shows all available methods within each single class!
bright colors: Methods that are defined in this class; pale colors: inherited methods
