Dear NI
I would like to have the possibility to add shift registers to case structures, either when used as state machines or true/false cases. There should be two options, namely a shift register that works as a normal shift register, as we know fro while loop/for loop, and then a new type of shift register that's specific for a particular case/state - sort of a LV2 global in disguise as a shift register for one particular case.
In a state machine the shift registers are often wired to the outside while loop, why not just use the case structure as the carrier of the **bleep** register.
keep up the good work.
/soren
