I inherited lots of VIs with complicated terminal connectors. It is a challenge to determine which terminal is associated with a given control.
Why not highlight the associated terminal when a front panel control has been selected?
In other words, currently when I select a terminal, the corresponding control is highlighted. I'm proposing that it should also work the other way -- when I select a control, the corresponding terminal gets highlighted.
I have just figured out a workaround, but it's clumsy. I can temporarily delete the control, observe which terminal goes white, and then immediately restore it with Control Z. But my proposed solution would be cleaner.
Duplicate of http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Connector-Pane-Show-position-of-selected-controls-indi...
