User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
Via this link, I learned, "If automatic tool selection is disabled, you can use the Wiring tool to select the control or indicator first and then select the terminal."
I happen to like using the automatic tool selection, so can this be an option when automatic tool selection is enabled?
E.g. if one (and only one) control/indicator is selected, clicking on a connector pane terminal will connect the control/indicator.
(I can't count the number of times I've *tried* to do this, even though it didn't work.)
-joeorbob
