The issue is that there are some situation where we have multiple developers using the same PC (Ex. limited number of test stations where HW/SW integration is performed). The last developer on the station changes the Environment Options to their desired settings.
To allow a developer to quickly switch to their preferred set of Environment Options, we would like a feature that would allow the following from the LabVIEW Splash Screen: (see image suggestion below)
Save current Environmental Option settings and assign that set a name.
Export/Import to from system using a file.
List the Environment Option sets currently on the system in the Tools menu
Duplicate of https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Move-LabVIEW-INI-other-config-setups-to-User-folder/i...
