User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
Often when I edit several files in a project, I end up affecting some files that I did not realize. Sometimes this is due to edit made to common files even before I opened the project. In any case, I need to save the newly recompiled VIs. But, since I did not directly edit them, they were not automaticlaly checked out. So, when I try to close the calling VIs, I get this dialog:
The problem is, since these were not checked out, they are still read only and I cannot save them. There is no simple way to check this files out of SCC either. So, I am stuck trying to find them in the hirarchy and then check them out before I can close the VIs.
All I want is some way to either check these out or find them quickly in my project so I can check them out from there.
