mawodorfer
Run executable at end of installation also for *.reg or *.bat files
Status: Declined
Any idea that has received less than 4 kudos within 4 years after posting will be automatically declined.
When creating an Installer for a Labview project, make it possible to execute not only exe files after installation. It shoult be also possible to execute *.reg or *.bat or other files.
This should work for the two options on the Advanced page of the Installer property dialog:
Best Regards
Martin
4 Comments
Mads
But you can. Just add a path to a .bat file and it gets executed without any problems.
mniedernhuber
Look at "Hiden Start" tool from ntwind software
http://www.ntwind.com/software/hstart.html
shb
But I can only run *.exe and *.bat files. Running other files would still be usable.
*.cmd, the newer file extension for batch files (see Batch file in wikipedia)
Because there seems to be no difference to bat files (see Difference Between Cmd And BatFile) this should be no problem
Maybe also some other script files like *.vbs, *.js or *.ps1
Of course we can start all this files by writing a bat file which runs them. This is also the simplest possibility for calling several executables, because only one can be selected. But it is a bit old fashioned.
Darren
Proven Zealot
Status changed to: Declined
