Two more suggestions
There has also been a need for rising edge and falling edge triggers for boolean values instead of having to manually code this in every time. I know this would take extra memory space but could be turned on or off maybe in the control settings dialog.
I also have to manually code in time delay functions because everything I do is in loops with parallel code. The timers can't execute properly this way and would be nice to be able to use the built-in timing functions instead of hand-coding.
