According to the increasing number of questions about this communication protocol, it would be time to rewrite the MODBUS library. I also suggest to add it to the NI device drivers installer.
This could be the place to list the expected modifications. Some comments and bugs are already listed in above linked page.
As the product manager of SAPHIR I greatly appreciate you mention our toolkits in your comment. Hope you understand I won't going to kudo your idea 😉 but encourage people to test and use our add-ons.
About the commercialization of our add-ons, I understand this could be a concern for people and I'd like to explain why it's not free. Since 1989, the main activity of SAPHIR is to develop and integrate acquisition signal processing solutions for our customers. SAPHIR add-ons are the result of real world needs, but remain a small part of our business. ModBusVIEW first release was in 1994, since then, we have been enhancing and testing it for every new version of LabVIEW. We do our best to provide more than a set of VIs (for example you can easily test communication without writting code or have a simulated slave/server to help you in your development). At last, we have improve our organisation to provide a better support to all of our customers and we hope to be provide it at least for the 20 next years 🙂
All these work done on these add-ons represent many developper (experienced one) hours. Having customers for these add-ons help us to continue the support of them.
I take the opportunity of your idea to tell people that we continuously listen for feedback from users to improve our tools. Feel free to add your comments here or if you prefer to contact us directly, use this e-mail : support@saphir.fr
We are just trying to make LabVIEW talk to an instrument using MODBUS. Right now, we don't want to spend money because it's just a test, then we are using the free library. I agree with JB, but NI should keep the distance to the Sphir's package. Later a user of the free library may need more power, then is when Saphir's library may fit. Actually is a free advertisement to Saphir's product.
Keep it update is necessary Like the idea of having it among the other drivers. Kudos!
I didn't change much of the underlying code, though I did make a couple of minor tweaks to improve functionality. Mostly I just ditched the llb, cleaned up the code, made things typedefs and commented as much as I could. (This took me several hours -- the stock code is not pretty.) Sorry, I'd share my version, but my company technically owns the code.
My point is that the library itself has worked flawlessly for us for several years, it's just sloppy and not well documented as offered. I literally use the TCP version of this code day in and day out without any problem. I use the RS-485 version quite a bit, but not as much as the TCP. Again, I can't recall any functional issues with the code itself. (issues with RS-485 hardware, certainly.) I will also add the disclaimer that I have only used the driver for Modbus master functionality, not implementing a Modbus slave.
In the event that NI decide not to follow your idea, this option has worked reasonably well for me.
I would definitely vote for NI releasing an "official" version that doesn't involve shared variables, though. I'm all for keeping things simple. (i.e. forgoing extra layers like shared variables) Just my opinion.
If the existing library could be fixed and re-posted by NI it would be a good stop-gap measure. I also agree with the comments on the ModBus download page that using shared variables with the requirement to install a costly DSC runtime on each customer's computer is not workable. Plus, I can't get an evaluation version to even show my customer how it would work.
I am required to provide my customers with Installer DVD's and the current situation does not allow me to do this because DSC is a seperate license.
I have Kudo-ed your idea and thanks for doing this.
I haven't used the NI Modbus library, nor have I purchased/used the SAPHIR offering. Some time back I needed to communicate with a SMC valve controller using Modbus/TCP, and like others here, ended up "rolling my own". Then I encountered the need with a totally different TCP device (Spectrum Power DC SmartStart), modified my library a bit, and re-used it. Then a third device, this one RTU (AccuEnergy Acuvim-L), and re-used it.
Here were my goals in writing a library package:
- that it be pure-G (even though I'm only using it, personally, under Windows). Why? Because that's the right thing to do, and takes no more effort. No DLLs, no NSV, DSC add-ons, etc.
- that it be built on VISA. Why? So I can support both Modbus/TCP and Modbus/RTU with the same library. It tests the VISA class at runtime, so if you open a VISA SOCKET, the code implements TCP, if it's a Serial INSTR, the code uses RTU.
I didn't create a complete "solution" as I'm sure SAPHIR offers (no network explorer, slave emulation, etc).
If NI chooses to follow JB's idea, I hope they make it robust and platform-agnostic.
Until then, I can probably offer what I've got to others as long as it doesn't become too big a support time sink.
Dave
David Boyd Sr. Test Engineer Abbott Labs (lapsed) Certified LabVIEW Developer
I wouldn't consider that link to be the NI modbus library. It is a community example by "smithd". I don't know how good it is or what it is based on. The download links in there are definitely broken. I wouldn't use it.
The "official" Modbus library is here MODBUS Library for LabVIEW. It is the latest I know of because it uses polymorphic versions of the VI's. (The NI Modbus library before this one did not use polymorphic VI's.
