User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
I'm not sure if this is a bug report or a feature request, but I think it should be fixed/implemented, all the same 🙂
If you right-click on a Boolean funtion (And, Or, Exclusive Or, Not, etc.) and replace with a Compoint Arithmetic (CA) function, the CA function is always set to the "Or" configuration. I would expect it to be smart and put the CA node into a configuration (including negation/inversion dots) that is equivalent to the Boolean function that it replaces.
