Wouldn't it be nice if Probes window had a drag'n'drop reorder functionality, maybe even a Sort?
Often you (I) place a couple of probes, maybe add some in another VI and then go back and add one earlier in a block diagram.
Is this a problem? Well, it's not breaking, but i'd like probe 1 to be the earliest executed probe and so on. Often execution order can easily be something like 13, 19, 3 and drag'n'drop #3 below the #19 would the shift them as 3, 13, 19. (Similar to how Reorder Case works)
It'd be nice if you could drag this probe in the probe window and it'd change numbers accordingly (switch/reorder within the VI).
Maybe even have Sort button that simply renumbers all as they're shown in the probe window.
It's somewhat similar, but different, to Altenbachs switcheroo idea: https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Probe-switcheroo/idi-p/3126138
