The Ctrl-Space-Ctrl-R Quick Drop keyboard shortcut to remove and rewire block diagram objects currently doesn't do anything with the [Shift] modifier. What if Ctrl-Space-Ctrl-[Shift]-R removed unwired terminals on bundle, Concatenate Strings, Build Array, etc.?
Darren: The quick drop idea is a nice workaround, but I think the original idea is a better implementation than another magic keyboard incantation. I kudos this idea.
As for the idea of adding it to Block Diagram Cleanup: I like that idea too, but the direct menu item on the node still seems like a useful tool. I suppose you could argue that since BDC can be limited only to selected nodes, that if you just selected one node and hit ctrl+u that it could remove the excess terminals, but that's an indirect way to get the effect, I think. So, still kudos to the original.
I agree that it should be a right-click option on the node. That being said, we have a much better chance of seeing the magic Quick Drop implementation sooner...much sooner. 😉
This functionality was added to Quick Drop in LabVIEW 2012 and later. Select a growable node with extra terminals, press Ctrl-Space, then Ctrl-Shift-R, and all the unwired terminals will be removed. The shortcut currently supports the following growable nodes:
Bundle, Bundle By Name, Unbundle By Name, Build Array, Concatenate Strings, Merge Errors, Property Node
Other growable nodes are not currently supported due to some limitations in VI Scripting.
That's awesome news. The Format Into String would be the next one I would like.
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
