User | Kudos |
23 | |
11 | |
7 | |
4 | |
3 |
When working with reentrant VIs, every time you double click an instance of a reentrant vi on the block diagram, the cloned instance is opened. This is fine during debugging but during development when you want to modify the actual code this requires that you open a clone, then CTRL+M to open the actual master vi. Much more frustrating if you have to dig several VIs deep through a highly reentrant hierarchy.
We have CTRL+RT Click to open the block diagram directly, how about something like ALT+RT Click to open the master VI instead of the clone.
Under normal development this is not such an issue but if you happen to be working with LV FPGA, just about everything is reentrant.
Any idea that has received less than 8 kudos within 8 years after posting will be automatically declined.
