There is a tool tip in the list on the Getting Started Window. But I can't say I have ever seen a tool tip for a menu item in any application.
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
I've seen it in Inkscape, which is the inspiration for this idea:
> Comparing branches\revisions simultaneously. Doesn't happen that often, but it happens.
This was my use case. I had also saved the project for a previous version, which was then opened for a quick sanity check. This led to three visually identical project listings in Recent Projects.
I think it will appear in the "Recent files" menu more often, as I often edit VIs with the same name, for instance when implementing a method in all children of a class. Then the VI name doesn't mean anything, without the class name. And the class name will get replaced by "…".
