User | Kudos |
18 | |
17 | |
10 | |
5 | |
3 |
Today, when adding new event, the Event Data Node is duplicated from the previous event.
Sometimes, this node does not match the new event and breaks the code.
Simple example: When the current event is "Menu Selection (User)" with node chosen "ItemTag". Add new event like "Panel Close?". The new event will be created with "ItemTag" node, and the code will be broken.
Of course, there are many more examples for that, and this is happening quite a lot.
Instead, LabVIEW can choose the first node that matches the new event.
Amir.
