If you wanted to use a lot of functions from the same palette, you have to either keep going back through the context sensitive Replace/Create menu or manually search back over to the palette through the Functions palette to get to the functions you need.
Wouldn't it be nicer if we could pin that palette down directly from the context menu?
If this has already been implemented in LabVIEW 2012, give this idea a miss!
