Ravi_Beniwal
Pane Size or splitter position
Status: Declined
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
It would be nice to be able to set the size of a pane and/or set the position of a splitter.
4 Comments
Ravi_Beniwal
This would be helpful when you are using a splitter to create a toolbar or statusbar or section titles and want exactly the same size for these elements in all your VIs.
tst
Knight of NI Knight of NI
Knight of NI
There is a property for this which can be accessed programmaticaly. I'm not sure if it's also available in the GUI, although if it would be, I would assume it would be in the property page for the pane.
___________________
Try to take over the world!
Ravi_Beniwal
You can do it programatically, but I'm dreaming about being able to position/resize in edit mode as easily as we resize Other FP objects (select the objects, click "Set Width and Height...", etc.)
Darren
Proven Zealot
Status changed to: Declined
