Hi
This Idea is to add a event case from edit event window of Event Structure.
The use case for it is when we start making a block diagram, after creating the front panel, we wanted to handle the events for the control on the front panel.
Now we create a event structure on the block diagram and do right click and click on "Edit Events Handled by this case" or "Add Event case". For adding new event case we always have to go to the event structure and click on "Add Event case" and then edit the event in the "Edit Events" window. How ever if we will be having an option to "Add event Case" on the same "Edit Events" window we can save a little time..
Duplicate of http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Add-Add-event-case-to-event-dialog/idi-p/970140
