User | Kudos |
18 | |
5 | |
4 | |
4 | |
4 |
This is written as both an Idea and as a Community Nugget.
Did you know there exists a function that decreases code fragility when it comes to typecasting and type converting datatypes? It's called 'Coerce to Type', and I bet you've never heard of this function unless you have kept up with this conversation. Thanks to RandyP for creating that Idea which culminated in a 'public' release of the Coerce to Type function.
Since that post, I have become aware of potential risks/bugs I had been proliferating in my coding style. First, I will briefly describe my understanding of the difference between typecasting and typeconverting in the context of LabVIEW. Next, I'll show a few use cases where this node increases code robustness. Finally, it's up to you to Kudos this Idea so we get Coerce to Type officially supported and in the palette!
Simply, "type converting" preserves the value of a wire, and "typecasting" preserves the raw bits that express that value on a wire. These two concepts are not interchangeable - they perform distinctly different data transfer functions (which is why they show up on two separate subpalettes: "Numeric>>Conversion" and "Numeric>>Data Manipulation"). Then there's this new function: Coerce to Type. I think of it as a Coerce-Cast combo. The data input is first Coerced to the datatype harvested from the top input, and then it is typecasted to that type.
Dynamic event registration is sensitive to the name on the wire, and for documentation's sake it has historically been important to typecast the event source ref to achieve a good name. Well, typecasting refs can get you into trouble (ask Ben), especially if you change the source control type while forgetting to update your "pretty name" ref constant.
My next favorite example is when you need to coerce a numeric datatype into an enum. Sometimes it's impossible to control the source datatype of an integer, while it's desirable to typecast the value into an enum for self-documented syntax inside your app.
For instance, take the "standard" integer datatype in LabVIEW - I32 - and cast it to an enum. You're going to get some unexpected results (assuming, you expected the *value* to be preserved). Consider the following scenario:
The Coerce To Type function is supported in LabVIEW 2018 and later. It is available in Quick Drop, and in the Functions > Numeric > Conversion subpalette.
