User | Kudos |
15 | |
6 | |
4 | |
4 | |
2 |
The LabVIEW Help for the OPC UA Connect VI has this statement in the description of the "OPC UA data change event" output: "NI does not recommend using this output."
The example VI "Data Access Client.vi" inside "OPC UA Demo.lvlib" uses this output. Could it be possible to add a possible explanation as to why in the Example the "OPC UA data change event" output is used? Or could the Help for the OPC UA Connect VI be modified?
Example:
Help documentation:
Filed as bug
