EstebanF
OPC UA: Contradiction between help documentation and example VI, some more infomation would be good.
Status: Declined
Filed as bug
The LabVIEW Help for the OPC UA Connect VI has this statement in the description of the "OPC UA data change event" output: "NI does not recommend using this output."
The example VI "Data Access Client.vi" inside "OPC UA Demo.lvlib" uses this output. Could it be possible to add a possible explanation as to why in the Example the "OPC UA data change event" output is used? Or could the Help for the OPC UA Connect VI be modified?
Example:
Help documentation:
3 Comments
AristosQueue (NI)
NI Employee (retired)
I have tried to find someone who knows the history of that example, but I have been unable to find anyone who knows definitively. I believe that the example was written early and the note about "NI does not recommend..." was added later, and the example was never updated. That toolkit is outside of LabVIEW
I will file a bug report to update the example to not use the terminal.
AristosQueue (NI)
Filed as bug 1913507.
Christina_R
Status changed to: Declined
Filed as bug
Christina Rogers
Principal Product Owner, LabVIEW R&D
