Well as the title says...
In the string constant you are able to make a scrollbar visible but this is still inconvenient when only see 2 lines of your whole string when you have a string constant of 50 lines or so... and you 9 out 10 times you don't want to create a bigger field because it messes with your diagram.
Therefore a small popup with a only a large textfield would grately simplify things.
I came up with this idea when I was writing a error message and there wasn't much space to type the string in, I also had this, http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Need-Edit-Window-for-New-Cluster-Constants/idi-p/12082..., idea in my backhead.
What do you guys think?
