User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
I'd like to suggest that the error ring dialog ("Select Error") have an entry for a search expression.
For instance, I'm looking for an error code for an index out of range. I might enter, "index" or "range" as the search term, and browse the resulting error codes whose descriptions include that text.
While I don't find myself using the error ring itself very often, I do use the resulting dialog quite a bit to browse for appropriate error codes. The trouble is that there are a lot of error codes and you could be staring at them for quite a while looking for the right code.
Thanks!
Mr. Jim
Available in LabVIEW 2019 and later. The 'Select Error' dialog for configuring an Error Ring now has a 'Filter' string to filter the list of errors.
