in LV2009 a new set of VIs have been published for working with configuration VIs. They are now part of config.lvlib. But some VIs of config.lvlib are marked private, therefore I cannot use these VIs as Sub-VIs, if the calling VI is not part of config.lvlib. This is bad (at least for me), since I have written some tools to load a configuration directly from a string and not from a file. To do this in LV2009, I need these private VIs, which I cannot use without changing config.lvlib.
Therefore I suggest to make all VIs of config.lvlib public. In fact, is there a good reason, why these are private in the first place?
Marc
