It would be great if one could pull FPGA Bitfiles/changed Xilinx IP without recompiling the code / re-configuring the IP cores.
Currently it seems that I need to copy the Xilinx IP via the Filesystem (e.g. network-drives) after pulling a new version from a git repository.
This works since git doesn't detect any change (no commit required), but the modification date is preserved. But it is very annoying.
For FPGA bitfiles this trick doesn't work for me, at least not if the path doesn't perfectly match.
