About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Top Kudoed Authors
Make Case Selector
I don't know how many times I've added a case statement post-programming, but I do know that there isn't an easy way to make a tunnel the case selector.  Usually I delete the tunnel and then drag the case selector down and then rewire, there should be an easier way.  For loops and while loops have an easy way to index/unindex or replace with shift register, why can't a case statement be the same?
18 Comments
Knight of NI
Eximo, what you are proposing is actually a different idea and should be submitted separately.  But do a search first.  There are all ready several ideas along the lines of "multiple case selectors".  Honestly, I don't see what you are proposing in your lower left idea as being a real improvement over the upper right picture.
temp initial case select or image.pngOr this
-Regards
eximo
_______________________________________________
UofL Bioengineering M.S.
Neuronetrix
"I had rather be right than be president" -Henry Clay
Status changed to: In Development
Grant H.
LabVIEW Product Marketing Manager
Example Gatekeeper
Status changed to: In Beta
DNatt, LV R&D
Example Gatekeeper
Status changed to: Completed
Implemented in LabVIEW 2014
DNatt, LV R&D
Trusted Enthusiast
Trusted Enthusiast
Now that this is implemente, what about the reverse action: disconnecting the Case Selector from an incoming wire while letting the wire go through (thus becoming a tunnel)?
The Case Selector could be pushed aside or just left where it is (with the risk of confusion).
Knight of NI
X, just choose something else to be the case selector.  It will be the same amount of effort for you.
The discussions from the Advanced User Track is not over. Join in the conversation: 2016 Advanced Users Track
Trusted Enthusiast
Trusted Enthusiast
That would work.
