About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Top Kudoed Authors
Make Case Selector
I don't know how many times I've added a case statement post-programming, but I do know that there isn't an easy way to make a tunnel the case selector.  Usually I delete the tunnel and then drag the case selector down and then rewire, there should be an easier way.  For loops and while loops have an easy way to index/unindex or replace with shift register, why can't a case statement be the same?
21 Comments
What would happen is the case selector was already wired?  would this option be grayed out?  Would the wired node be replaced with a tunnel?
Copyright © 2004-2018 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 2.5 License.
Maybe instead of an option that said "Make Case Selector from Tunnel" it would say "Move Case Selector to Tunnel", something to that effect. As far as the existing case selector, I would just make it a tunnel.
Message Edited by NelsonUWP on 07-31-2009 09:52 AM
Knight of NI
How about just dragging the existing unwired case selector on top of a tunnel, wait a second until the tunnel "lights up", release the mouse. --> tunnel changes to case selector.
(At the same time we should also remove the restriction that the case selector must be on the left edge. Many times I wish I could place it on the top or bottom edge for a cleaner code layout, but that's proably a different idea).
LabVIEW Champion Do more with less code and in less time
Also, make sure the 'Linked input terminal' menu will work properly.
Wouldn't this be easier?  It's already possible with the JKI RCF.
JKI Blog
@altenbach, I like that too. Something, anything, is better than what is already in place.... which is nothing.
Knight of NI Knight of NI
Knight of NI
You can find two RCF plugins that do this here.
___________________
Try to take over the world!
Please, please don't use the top and bottom edges of structures for tunnels - it's bad style IMHO. Bad style Smiley Happy.
But the right-click (or drag-drop) to select new selector receives my kudos...
Cheers,
Steen
CLA, CTA, CLED & LabVIEW Champion
I was just about to post this reccomendation, but you beat me to it!
I am constantly deleting my tunnel, and re-connecting it to the selector.  It'd be great to have this function.
Kudos.
http://www.medicollector.com
It would be great if a case could have multiple selectors under this situation.  Right click to make something a case selector, and select AND or OR.  It will reduce clutter as the AND or OR statement will now be an attached module to the case.
Initial code
temp case selector combo selection.PNGconcept case selector
-Regards
eximo
_______________________________________________
UofL Bioengineering M.S.
Neuronetrix
"I had rather be right than be president" -Henry Clay
