NelsonUWP
Make Case Selector
Status: Completed
Implemented in LabVIEW 2014
I don't know how many times I've added a case statement post-programming, but I do know that there isn't an easy way to make a tunnel the case selector.  Usually I delete the tunnel and then drag the case selector down and then rewire, there should be an easier way.  For loops and while loops have an easy way to index/unindex or replace with shift register, why can't a case statement be the same?
21 Comments
RavensFan
Knight of NI
Eximo, what you are proposing is actually a different idea and should be submitted separately.  But do a search first.  There are all ready several ideas along the lines of "multiple case selectors".  Honestly, I don't see what you are proposing in your lower left idea as being a real improvement over the upper right picture.
eximo
temp initial case select or image.pngOr this
-Regards
eximo
_______________________________________________
UofL Bioengineering M.S.
Neuronetrix
"I had rather be right than be president" -Henry Clay
G-Money
NI Employee (retired)
Status changed to: In Development
Darren
Proven Zealot
Status changed to: In Beta
Darren
Proven Zealot
Status changed to: Completed
X.
Trusted Enthusiast
Trusted Enthusiast
Now that this is implemente, what about the reverse action: disconnecting the Case Selector from an incoming wire while letting the wire go through (thus becoming a tunnel)?
The Case Selector could be pushed aside or just left where it is (with the risk of confusion).
crossrulz
Knight of NI
X, just choose something else to be the case selector.  It will be the same amount of effort for you.
GCentral
X.
Trusted Enthusiast
Trusted Enthusiast
That would work.
BVSmith
I'm running LV 2016 and 2017 and I don't see that "Make Case Selector" anywhere in the right-click menu:
Brian Smith
Advanced Light Source
Lawrence Berkeley National Laboratory
crossrulz
Knight of NI
BVSmith, the first option is what you are looking for.  "Replace with Case Selector"
GCentral
