User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
In audio industry I always use logorathmic frequency (X) axis and often also logarithmic Y-axis. Like from 20 to 20kHz but not linear as in Labview but logarithmic as in Bode-diagram.
Today, labview doesn't understand these. They can show them if you select that your graph-window to have logarithmic axis. But the waveform-type itself doesn't. In the waveform type you have f0, df and Y. But df is not a constant if you have log axis.
Also, the limit-testing methods doesn't understand logarithmic axis either.
I would appreciate it if in a future version of Labview it will allow the use of logarithmic axis.
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
