Functionality available with Load Warning feature that identifies missing drivers and add-ons when loading a project.
I distribuute a lot of code, and sometimes it's difficult to tell my users what they need to install in order to run that code. It would be nice if I (or a user) could run a built in LabVIEW utility that tells me what a given VI needs to run.
For example, do I need DAQmx, Mathscript, Robotics?
If you're the developer shouldn't you know what you need, by definition? Are you creating installers? This allow you to include the required installers.
But, smercurio_fc, what if I'm not the developer? What if I am given a VI and it is broken because subVIs are missing? That happens to me all the time with VIs attached to bug reports. I can see the value in a feature like this.
I would like this feature in the application builder's "Additional Installers" section.
Even if you are the developer it is difficult to always know when a requirement kicks in. Does the math in the code I wrote two years ago require the math kernel libraries? Or how about the locked VI that I got from the net? If the application builder could select the modules that are needed, and only those, then I would not need to uncheck things like NI Logos all the time, nor would I forget to include the NI-VISA RunTime.
(This auto-selection could be ON by default, but should be possible to turn off if you happened to want an additional module for other reasons.)
I agree with Aristos, the number of times I've clicked open a VI only to find its broken because something is missing. So I can see this could be very useful.
I have to agree with this idea, since we just came across a situation when trying to build an executable with VI's from the NI Report Generation Palette. Little did I know (until I searched on the NI Forums) that I had to manually add two folders from vi.lib (LVClass & NIReport.llb).
