Key focus Event
Status: New
i propose to add a "Key Focus" event for each control. We already have Mouse events (leaving, entering) - but when the user (or the programmer) prefers the keyboard (with proper tabbing setup) you have to poll each interesting control for it's "Key Focus" property to initiate a user event...
So please:
Add a "Got Focus" (and additionally a "Lost Focus") event to the event structure!
24 Comments
MinerHokieRamp
I spent a lot of time searching the forum on how to do this and landed here. I don't see this feature in LV2013.
Jeffrey Bledsoe
Electrical Engineer
AristosQueue (NI)
NI Employee (retired)
MinerHokieRamp: The feature is not in 2013... nor will it be in 2016. It hasn't made the cut to get attention. It's got fairly high kudos, but other projects keep winning out.
PeppeJeppe
Like everyone else I ended up here. Please add it!! It takes to much execution time to poll the focus property.
crossrulz
Knight of NI
PeppeJeppe,
If you like the idea, be sure to give it a kudos.  Your little comment will not draw NI's attention.  It is the kudo count that is supposed to be the representative of the community's desire for the feature.
GCentral
PeppeJeppe
I'm blind because I cant find where to click to give it kudos 😉
PeppeJeppe
I found it 😄
crossrulz
Knight of NI
The star at the top of the thread.  It takes a little time for it to register, but you will see it slightly change colors when it does register.
GCentral
littlesphaeroid
Additionally, an event for a VI becoming idle (or changing execution state) would be great, so that processes can quit when their parent process goes idle. Now we have to poll the execution state on event timeout to determine of a parent VI is idle.
_____________
Creator of the BundleMagic plugin for LabVIEW!
crossrulz
Knight of NI
littlespaeroid, are you referring to dynamically called "children" VIs?
Regardless, that should be in a different idea (that I think has already been suggested)
GCentral
littlesphaeroid
Yes, it should be a different idea, sorry. And yes, if a VI is called with async call and forget, normally we want it to stop when the calling VI becomes idle. We could do this with events sent from the calling VI or top-level application, but if the event doesn't get sent, for whatever reason, you can end up with invisible processes running all over the place. My solution is to poll the running state of the calling VI. But registering for an event on the execution state of that VI would be much more elegant.
_____________
