Inspired during discussion in this nugget of Darren:
In my opinion there are a lot of good reasons to inline nearly every VI, which is reentrant. I see only three reasons for not using inlining:
1.) use recursive code (which I seldom use)
2.) call the reentrant VI dynamically (which I use more often than recursion, but still I use this seldom)
3.) you don't want to recompile every time, when you change the reentrant sub-VI
Of course you can disable inlining, if you want. It is only enabled after you set the VI reentrant. This behavior could be controlled via LabVIEW options.
Marc
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
