Taylorh140
Index array Improvements
Status: New
There are two things that bother me about the index array. I think these changes would be useful to nearly all LabVIEW users.
  1. The default value is not optional (for integers always zero, a very useful value) There should be a way to set the desired value if the index is out of bounds.
  2. There should be a way to get rather the index is out of bounds from this primitive since this has to be check anyhow to know whether to use the default value.Image 2.png should look something like this: Image 3.png
The lack of these items usually proves to generate code that looks much uglier than necessary.
Although I do not know the internal workings of this primitive it would be hard for me to believe that this would have much of a performance impact. Also, bound checking arrays is necessary for many algorithms, why do it twice?
2 Comments
AristosQueue (NI)
NI Employee (retired)
The bounds check output is a duplicate:
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Index-array-with-index-valid-indicator/idi-p/3268460
That idea was Declined because it only got 3 kudos after 3 years.
I find no record of the default value specifier being suggested before. Therefore, I will leave this idea open.
crossrulz
Knight of NI
I managed to find a related as in it is for the Reshape Array.
GCentral
