Configurable VIs have one or more right-click options. Some VIs document these options by changing the icon, such as In Range and Coerce and Write to Text File.
However, VIs with smaller icons are less amenable to this approach. Examples include many Comparison VIs (Comparison Mode) and Array to Cluster (Cluster Size). Others have suggested adding a configure icon or more specifically making cluster size an input for Array to Cluster. I'd like NI to include a "Polymorphic VI Selector" style menu with configurable VIs.
This menu could be used to set an option and provide visual confirmation of the selection. This display could also be hidden by deselecting in the Visible Items right-click menu. I suspect much of the code needed to implement this idea is already in LabVIEW.
