User | Kudos |
4 | |
4 | |
4 | |
2 | |
2 |
It would be very helpful if there was a way of seeing the full lists of two different enum type defs at the same time and edit both lists simultaneously. Right now if you click the button to edit elements in a enum it locks out LabView so that you cannot see the list of elements in another enum. It is also really frustrating that in the edit window there is no way to increase the size so that you can see more than 6 elements or make the Item column larger to see long enum elements.
Then there is no way to add more than 6 items easily to the bottom of the list. You have to hit insert and it puts the element second from last and then you have to move down. It should be more like an array or table where you can just type and hit enter and add a lot of elements easily, resize and see as many as you want without having to scroll if you want a full window of the enum.
