Currently, while inserting node by default insert quick drop Ctrl + I, it inserts node without considering wire branching. Check the picture - first is target place, and second - where it is actually inserted. Using insert menu from right-click menu works fine, b/c it inserts function exactly to proper place.
It would be nice to update this quick drop, to have the same behaviour, as non-quick drop functionality.
Sincerely, kosist90
The issue was caused by a third-party add-on. In the current LabVIEW release, the 'Insert' Quick Drop plugin properly inserts a node on a single selected wire segment.
