User | Kudos |
4 | |
2 | |
2 | |
1 | |
1 |
I would like a key or click combination to highlight the entire wire. Structure borders are brick walls for the highlight feature, so you must follow the wire to the structure, then double-click the other side of the tunnel in order to continue tracing the data flow.
For example, if I double click to the right of the While Loop, I get this:
What I want to get is this:
What do you all do when you're tracing wires through structures?
