The Help window doesn't remember the window state when reopening it. If it was previously maximised it reopens it in the normal state with the size of the maximised window. Changing to maximised should also not overwrite the stored normal state size and posistion.
I frequently open the help window and this becomes annoying:
I've also encountered this with block diagram windows when opening on another PC. Instead of returning to the maximised state it opens in the normal state with maximised dimensions.
Using LV2018 32 bit
Highly recommended open source screen capture software (useful for bug reports). https://getsharex.com/
