About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Top Kudoed Authors
Handle invalid characters in filenames during build
NI LabVIEW allows VIs with invalid characters such as "?" in the filename inside an LLB file as shown below:
However when it comes to building a Source Distribution / TestStand Deployment that uses this file it returns an error as shown below:
This inconsistency within LabVIEW is quite frustrating where one part allows invalid characters in the filename and another part will return an error. Since the invalid characters are allowed in VI filenames within LLB files I would suggest that the LabVIEW build tools also handle them graciously.
During the build process it could quite easily rename the file "pi40iv Can Connect Channel?.vi" to "pi40iv Can Connect Channel_.vi"  and link the VIs that use it to the newly renamed file. The build tools already contain the ability to rename files by adding prefixes so something like this would not be that difficult.
While people may argue to just rename the filename within the LLB and be done with it, the fact that the LLB is a perfectly valid file in the Development Environment but causes problems when trying to do a build is a problem that should be rectified.
The LLB in question is one that is not developed by us but is part of a Pickering Driver Installation obtained from the following location:
http://downloads.pickeringtest.info/downloads/drivers/IVI/
Therefore every time we install a new version of the driver we would need to rename the VI filename within the LLB file.
2 Comments
Trusted Enthusiast
We recently had a similar problem where a project (on Windows) had characters that are not allowed on Linux. When deploying to cRIO, there where no errors, but it didn't work either.
+1 for handling this properly.
There is a tool builtin, in the undocumented part of the vi.lib presented by Darren Nattinger in this slide deck.
https://forums.ni.com/t5/Hidden-Gems-in-vi-lib/Hidden-Gems-in-vi-lib-pptx/gpm-p/3502591
More specifically the bottom line on slide 24 is what you need to detect the faulty character in the file name.
It could and should be handled by a pre-build step by the programmer of the IVI driver.
Keep in mind that the presented slides is a delve into the undocumented part of the "vi.lib" so there may be dragons ahead.
BR
Jesper
