User | Kudos |
9 | |
5 | |
4 | |
4 | |
2 |
There are currently two NI toolkits which add a software layer on top of the automotive CAN bus.
The Automotive Diagnostic Command Set (ADCS) adds a couple of protocol standards like KWP2000 (ISO 14230), Diagnostics on CAN (ISO 15765, OBD-II), and Diagnostics over IP (ISO 13400). This is a pretty handy API when all you need is one of these protocols. But often when you need to communicate to an ECU, you also want have a normal Frame or Signal/Channel API where you get raw frame data, or engineering units on signals.
The ECU Measurement and Calibration (ECU M&C) adds XCP, and CCP capabilities on top of CAN allowing to read and write parameters based on predefined A2L files. This again is super handy, if the A2L you provide can be parsed, and if all you need to do is talk XCP or CCP to some hardware. But often times you also need to talk over a Frame or Signal/Channel API. And what if you need to also talk over some other protocol.
Every time I've had to use one of these toolkits, it has failed me in real world uses, because you generally don't want just one API you want severaal. And to get that kind of capabilities you often are going to close one API sessions type, and reopen another, then close that and reopen the first. This gets even more difficult when different hardware types either NI-CAN or NI-XNET are used. The application ends up being a tightly coupled mess.
This idea is to rewrite these two toolkits, to be as pure G implementation as possible. The reason I think this would be a good idea, is because with it you could debug issues with file parsing, which at the moment is a DLL call and hope it works, and it would allow for this toolkit to be used, independently of the hardware. Just give it some raw frames, and read data back. NI-XNET already has some of this type of functionality in the form of their Frame / Signal Conversion type, where it can convert from frames to signals without needing hardware. If these toolkits could support this similar raw type of mode then it would allow for more flexible and robust applications, and potentially being able to use these toolkits on other hardware types, or simulated hardware.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
