Mads
For loop parallelism across multiple remote targets
Status: New
We have cloud computing, virtual Machines, CPU virtualization etc. - There are numerous ways of achieving parallel and distributed computing, available at different architectural levels. The inherent parallel nature of the LabVIEW graphical programming means we can often achieve parallel computing without thinking.
-But in cases where the programmer actually needs to make a decision we now have the Loop Iteration Parallelism option.
If an action is to repeated multiple times and the execution of each run takes longer than the overhead of communicating the input data, execution code and/or output data across to multiple targets, parallelization can reduce the total execution time, and/or reduce the load on each target. Now, in some cases the execution time can justify parallelization even across slow communication channels.
What if we expanded the user-friendly loop iteration parallelization mechanism to also support remote processors?
  • On the targets we want to offer as execution hosts we will need to install a host service. This service might offer us the choice of offering all, or just a subset of the available cores.  Perhaps even decide this based on the current load on the target, or time of day(!). The targets can be of different platforms as long as the code is possible to recompile for it.
So how would this look like to the programmer? Well, we simply extend the for loop parallelization function dialog to something like this:
  • The loops should also allow this setup to be changed at run-time. You could have a general VI to define the default targets and establish a link to them, and each for loop could have input terminals to specify the parallelism options to be used at the time of execution.
  • Another fun consequence of this functionality would be that you can really distribute *any* part of you code across multiple targets simply by wrapping it in a 1-iteration only loop.
With this functionality in place getting 10 machines to work on a heavy problem instead of just one would really be as simple as drawing a for loop...Smiley Very Happy
2 Comments
GregSands
Good idea.  Though I think a single platform would be sufficient, and probably much more achievable.
Mads
Sure, that part is not crucial.
I'm not so sure it would raise the difficulty level that much, but the usefulness of cross-platform support would be limited to the development environment  (where there is a source code available to be recompiled, and a recompiler).
